[GRASS-user] v.lrs.where users wanted
Leonardo Lami
lami at faunalia.it
Thu Jul 5 04:51:10 EDT 2007
Ok, all rigth!
Under the Config menù there is the command "display font", it was
necessary just setting it.
Ciao
leonardo
Glynn Clements ha scritto:
> Markus Neteler wrote:
>>> No this problem with sqlite also if I can not again see the label also
>>> if I use v.clean/break and remove the "dangles" on the vectors.
>>> But I thin k the problem is in this output:
>>> unable to open font map '/usr/local/grass-6.3.cvs/fonts/.hmp': No such
>>> file or directory
>> Huh? Never see that problem... Apparently something went wrong when you
>> compiled lib/fonts/.
> That error message indicates that the current font name is the empty
> string. The current font should always be initialised by either
> mon.select or (for direct rendering) LOC_init(). It's possible that
> the current font has actually been set to the empty string, either by
> $GRASS_FONT being defined but empty or by a call to R_font("").
