[GRASS-user] v.lrs.where users wanted
Leonardo Lami lami at faunalia.it
Thu Jul 5 05:53:47 EDT 2007
This is my first result with v.lrs.segment...not encouraging...
the vector road_plus is a line (whitout nodes) that start and stop on
the lrs vector.
GRASS 6.3.cvs (spearfish60):~ > v.lrs.segment input=road_plus at router
output=route_lrs_labels_plus llayer=1 rsdriver=sqlite
rsdatabase=$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db rstable=route_lrs
--overwrite
DBMI-SQLite driver error:
Cannot open database: unable to open database file
ERRORE: Cannot open database for reference table
If I put the explicit rsdatabase path:
rsdatabase=/home/Documenti/datigrass/spearfish60/router/sqlite.db
rstable=route_lrs --overwrite
ATTENZIONE: Il vettoriale 'route_lrs_labels_plus' è già presente e sarà
            sovrascritto
<all stops>
<I press Return>
ATTENZIONE: Incorrect segment type:
<all stops>
<I press Return>
<all stops>
<I press Return>
and I must press ctrl-C
Any idea?
Leonardo
Leonardo Lami ha scritto:
> Ok, all rigth!
> Under the Config menù there is the command "display font",  it was
> necessary just setting it.
> Ciao
> leonardo
> Glynn Clements ha scritto:
>> Markus Neteler wrote:
>>>> No this problem with sqlite also if I can not again see the label also
>>>> if I use v.clean/break and remove the "dangles" on the vectors.
>>>> But I thin k the problem is in this output:
>>>> unable to open font map '/usr/local/grass-6.3.cvs/fonts/.hmp': No such
>>>> file or directory
>>> Huh? Never see that problem... Apparently something went wrong when you
>>> compiled lib/fonts/.
>> That error message indicates that the current font name is the empty
>> string. The current font should always be initialised by either
>> mon.select or (for direct rendering) LOC_init(). It's possible that
>> the current font has actually been set to the empty string, either by
>> $GRASS_FONT being defined but empty or by a call to R_font("").
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
