[GRASS-user] 1)Color rules problem loading srtm.hgt 2)Merge two raster
nikguitar nikguitar at gmail.com
Fri Jul 13 03:53:24 EDT 2007
>You can't do bathymetry with SRTM data.  DEM, yes.
I have found bathymetry data only in srtm files
(http://topex.ucsd.edu/WWW_html/srtm30_plus.html). Do you have another place
to search?
>Could you post the actual command you are using to import?  Are you
>using 1-arcsecond or 3-arcsecond SRTM data?
r.in.srtm -1
input=/Users/nik/Documents/files_nik/doc/rhul/works/phd/source/srtm_namibia/w020n40.srtm.hgt
output=bath
I have tried both, and both result in the same error
---Your color rules do not cover the whole range of data!---
---(rules -500.000000 to 8850.000000 but data 0.000000 to 65535.000000)----
>You might want to check out the GRASS Newsletters.  There's lots of good
>information there on working with SRTM data.
Ok, I'll dig better....
Thank you
View this message in context: http://www.nabble.com/1%29Color-rules-problem-loading-srtm.hgt-2%29Merge-two-raster-tf4069957.html#a11574923
Sent from the Grass - Users mailing list archive at Nabble.com.
