[GRASS-user] HDL import problem
sm399 at cam.ac.uk
sm399 at cam.ac.uk
Fri Jul 20 12:58:00 EDT 2007
Dear Users,
the problem I am trying to solve is not directly connected to GRASS
(although what I am trying to do is to extract info from a volume and then
import it into GRASS), but I was hoping there might be someone in the
community that has experience with the same kind of data.
I have been given some GPR geophysics data to visualise and use for vector
extraction in Paraview. The data was put together as parallel transects to
create a 3D volume with EKKO_3D. It was then imported and saved in T3D as a
volume HDF and it is saved with an extension .HDL.
I tried to import it into Paraview directly without success. I have also
been trying to find if there is a way to convert an hdf file into .hd5 but
have been unsuccessful in the endeavor. T3D can also store data as .raw but
even in this case I could not find the right translator to import it into
Paraview.
Could anyone suggest what to do in order to open this dataset in Paraview?
Yours gratefully,
Stefania Merlo
