[GRASS-user] Problem exporting an ascii file bigger than 2Gb
Raffaele Morelli raffaele.morelli at gmail.com
Wed Mar 14 07:28:03 EDT 2007
2007/3/14, Roberto Antolin <roberto.antolin at polimi.it>:
> Hello everybody,
> I'm trying to export into ascii a raster map about 250mill of cells with
> both r.out.ascii and r.out.gdal. But when the ascii file arrives to 2Gb,
> the module stops exporting the raster map. I'm not sure this is a GRASS
> problem since I used the option "--enable-largefile" during compilation.
> What do you think? Any hint on how to solve it?
Hi Roberto,
are you exporting into a fat32 or ext2/3partition? I had similar problem, no
grass related indeed.
In my experience writing stopped at 4Gb on a fat32 fs partition, but for
ext2/3 is 2Gb.
Look at http://www.suse.de/~aj/linux_lfs.html
Thanks,
> Roberto.
raffaele
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20070314/0e5fe1c2/attachment.html
