[GRASS-user] v.digit error message
pawan datta pawandatta at rediffmail.com
Wed May 23 05:22:22 EDT 2007
Hi all,
while digitizing roads for a watershed, the v.digit module stopped
responding. Nothing worked, so i had to restart GRASS. Then, i
rebuilt the topology of the vector file, but when i started the
v.digit again, i got this message:
v.digit map=roads bgcmd="d.rast comptopo53j3"
WARNING: coor files of vector 'roads at datta' is larger than it
should be
          (152007 bytes excess).
  100%
The file seems to work fine and without any problem, but I want to
be sure that ignoring this message cannot cause some problems
later. Could anybody please explain why this happens (it has
happened quite a no. of times now) and give some possible
suggestions.
Thanks a lot
Pawan
