[GRASS-user] Resolution size for v.to.rast of points
    Daniel Victoria
    daniel.victoria at gmail.com
    Fri May 25 08:46:14 EDT 2007
I believe you have to find out what is the shortest distance between
two of your points. Then set the resolution to half of that value.
Not sure how to do that in Grass but that's the idea.
Cheers
Daniel
On 5/25/07, Roy Sanderson <R.A.Sanderson at newcastle.ac.uk> wrote:
> Hello
> I'd be grateful if someone could advise on the appropriate use of v.to.rast
> on points vector data.  The issue is in selecting the maximum resolution
> that still correctly converts all the points, without losing any because
> two or more points end up in the same raster grid cell.  At the moment we
> are using a trial and error approach, by rasterising the points, then
> running r.stats to count the number of pixels.  I recall the old s.to.rast
> flagging a warning if the resolution was incorrect on rasterisation, but
> can't work out how to enable this in GRASS 6.2.
> Many thanks
> Roy
> Roy Sanderson
> Institute for Research on Environment and Sustainability
> Devonshire Building
> University of Newcastle
> Newcastle upon Tyne
> NE1 7RU
> United Kingdom
> Tel: +44 191 246 4835
> Fax: +44 191 246 4999
> http://www.ncl.ac.uk/environment/
> r.a.sanderson at newcastle.ac.uk
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
