[GRASS-user] problems exporting vector as a shapefile with polygons
Dylan Beaudette dylan.beaudette at gmail.com
Mon Nov 12 18:49:07 EST 2007
On Monday 12 November 2007 03:33:05 pm andrew haywood wrote:
> Dear List,
> I am having problems exporting a vector out as a shapefile with
> polygons. I seem to get only lines.
how about v.out.ogr in=xxx type=area ...
Dylan
> If I run v.info on my vector I get the following. Which states I have
> areas and centroids.
> Type of Map:  Vector (level: 2)                                          |
>  |   Number of points:       0               Number of areas:      3588
>  |   | Number of lines:        0               Number of islands:    1
>  |     | Number of boundaries:   14632           Number of faces:      0
>  |       | Number of centroids:    3588            Number of kernels:    0
>  |   Map is 3D:              0
>  |   | Number of dblinks:      1
>  |   Projection: UTM (zone 0)
>  |   | N: 5920000.000    S: 5828000.000                                | E:
>  | 452000.000    W: 296000.000                                  | B: 0.000
>  |        T: 0.000                                       |
>  |   Digitize threshold: 0.00000
> If I run the following command
> v.out.ogr -p input=grid_small type=area dsn=grid_small layer=1
> format=ESRI_Shapefile
> and then run the following
> ogrinfo  grid_small.shp grid_small
> I get only linestring and no polygons
> OGRFeature(grid_small):13540
>   cat (Real) = (null)
>   row (Real) = (null)
>   col (Real) = (null)
>   LINESTRING (406000 5852000 0,406000 5854000 0)
> when i import it into arcvie 3.x i only get a polyline shapefile.
> Any help on how to construct a polygon shapefile would be greatly
> appreciated.
> regards
> Andrew
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
