[GRASS-user] NVIZ and 3D polygon
Tue Nov 13 00:48:39 EST 2007
aswin indraprastha wrote:
> Dear All,
> I am doing 3D modeling of a complex urban area (buildings and
> topography) for my research.
> First, I try to look if Grass (via NVIZ) could handle 3D polygon.
> When I try to import my dxf model (modelled in SketchUp Pro) with
> v.in.dxf, everything is OK.
> But apparently, in NVIZ it came with error message :
> invalid command name ".middle.panelarea.panels.vect.mid.row2.label2"
>     while executing
> "$row2.label2 select"
Hi Aswin,
did you start NVIZ from the command line or from the menu?
after checking the region bounds/resolution with 'g.region -p' make a raster
surface to put it on.
  r.mapcalc zero=0
from the command line start NVIZ with
  nviz -q
then load the raster surface and the 3D vector manually.
You may want to set the raster to be transparent.
does that help?
Hamish
      ____________________________________________________________________________________
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
