[GRASS-user] import e00? sorry for repeat topic, but...
    Brandon M. Gabler
    bgabler at email.arizona.edu
    Mon Nov 19 13:12:24 EST 2007
I cannot find the answer to my specific problem through the existing
threads, nor can I properly search the GRASS list archives (that's
another issue, but when I click one of my search results, a DIFFERENT
message shows up unrelated to the link I clicked).
Here is my problem. I have a few e00 rasters from ArcGIS. When I view
them in ArcMap, everything is fine. When I import using GRASS, with
avcimport and e00conv installed, the maps display properly (I can see
the different categories, etc.). However, the z value is simply a *.
So when I query the file in a monitor, I get UTM-X | UTM-Y | *
Clearly, this is not the intended outcome! I do not get errors during
the import, and I have tried exporting the e00 in different formats
from ArcCatalog, and wondered if I should be converting my files to a
different format instead of dealing with ESRI e00?
The other thing I attempted is to convert the e00 to an ASCII file in
ArcInfo, then to import the ESRI ASCII in GRASS. Again, same result
as above.
Am I having projection issues? Do I need to first import the e00/
ASCII to a mapset with the same projection settings as the original
e00, then re-project, or is this unrelated? I think I had tried that
already, with the same result as above, but am willing to try again
if need be.
What other conversion options may work from within Arc?
Thanks,
Brandon
