[GRASS-user] identify features without cat
Martin Landa
landa.martin at gmail.com
Mon Oct 8 02:23:54 EDT 2007
Hi Dylan,
2007/10/8, Dylan Beaudette <dylan.beaudette at gmail.com>:
> After some frustration with the GRASS-R functionality as implemented
> via temp shapefiles, I realized that the source of the problem was
> features missing cat values.
> I poked around with v.edit, but did not see any simple way to ID or
> remove features missing a cat value. The '-c' option in v.out.ogr was
> a temporary fix, but I would like to be able to identify / remove
> cat-less features without using v.out.ogr .
to extract only features with category number using v.extract should work(?)
v.extract in=r out=rc list=1-9999
or
v.edit map=r cats=1-9999 tool=select
resp.
v.edit map=r cats=1-9999 tool=select -r
Martin
> Any tips on how to do this / or where work would need to be done?
> Cheers,
> Dylan
> PS: working with GRASS6-CVS
> grassuser mailing list
> grassuser at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grassuser
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
