[GRASS-user] identify features without cat [solved]
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Oct 8 13:50:30 EDT 2007
On Sunday 07 October 2007, Martin Landa wrote:
> Hi Dylan,
> 2007/10/8, Dylan Beaudette <dylan.beaudette at gmail.com>:
> > After some frustration with the GRASS-R functionality as implemented
> > via temp shapefiles, I realized that the source of the problem was
> > features missing cat values.
> > I poked around with v.edit, but did not see any simple way to ID or
> > remove features missing a cat value. The '-c' option in v.out.ogr was
> > a temporary fix, but I would like to be able to identify / remove
> > cat-less features without using v.out.ogr .
> to extract only features with category number using v.extract should
> work(?)
> v.extract in=r out=rc list=1-9999
> or
> v.edit map=r cats=1-9999 tool=select
> resp.
> v.edit map=r cats=1-9999 tool=select -r
> Martin
Thanks Martin. It turned out that the problem was associated with missing
centroids, and the v.extract list=1-999999 trick did not work...
Dylan
> > Any tips on how to do this / or where work would need to be done?
> > Cheers,
> > Dylan
> > PS: working with GRASS6-CVS
> > grassuser mailing list
> > grassuser at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grassuser
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
