[GRASS-user] [GRASSLIST:9838] Re: e00 import error?
Alpha GRASS
alpha.grass at gmail.com
Mon Oct 8 02:52:37 EDT 2007
Hi All,
I m working GRASS GIS 6.2.2RC1 version on Fedora 5.
While importing vector maps i am getting error like avcimport program not
found'.
I tried ti install avcimport library but makefile extension is .vc.
How to install this library on Linux.
Pls help in this regard,
Thanking you in Advance..
With Regards,
Ms. Ashwini
Otto Dassau wrote:
> On Sat, 14 Jan 2006, M S wrote:
> Hi,
> you need to install the missing AVCE00 and E00Compr libraries first
> http://avce00.maptools.org
> regards,
> Otto
>> user error maybe? this should be a standard polygon e00. i get this
>> error
>> on import. Is avcimport a seperate module installation or something?
>> v.in.e00 file=/home/johndoe/gis/maryland/PONET.E00 type=area
>> vect=counties
>> -v
>> which: no avcimport in (/usr/local/grass-6.0.1/bin:/usr/local/grass-6.0.1
>> /scripts:/usr/local/grass-6.0.1
>> /etc/dm/script:/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/mark/bin:)
>> v.in.e00: 'avcimport' program not found, install it first
View this message in context: http://www.nabble.com/-GRASSLIST%3A9827--e00-import-error--tf3116211.html#a13013370
Sent from the Grass - Users mailing list archive at Nabble.com.
