[GRASS-user] identify features without cat [solved]
Dylan Beaudette
dylan.beaudette at gmail.com
Mon Oct 8 13:49:30 EDT 2007
On Monday 08 October 2007, Hamish wrote:
> Dylan Beaudette wrote:
> > After some frustration with the GRASS-R functionality as implemented
> > via temp shapefiles, I realized that the source of the problem was
> > features missing cat values.
> I've just added a note about this to vectorintro.html as it is
> an unobvious feature of GRASS vector processing.
Great. It turned out that the problems I was experiencing were related to 2
things:
1. broken topology
2. areas without a centroid.
manual edits with v.digit fixed the first problem and v.category type=area
option=add fixed the second.
Just goes to show that garbage in = garbage out.
> > I poked around with v.edit, but did not see any simple way to ID or
> > remove features missing a cat value. The '-c' option in v.out.ogr was
> > a temporary fix, but I would like to be able to identify / remove
> > cat-less features without using v.out.ogr .
> > Any tips on how to do this / or where work would need to be done?
> to add category numbers use v.category or v.centroids.
> you might give all newly categorized features a cat number of 99999
> (cat=99999 step=0) then extract those to another map with v.extract
> and compare.
It might be a good idea in the manual to define the behavior of v.category,
when the input has features with and without centroids, and when the
option=add... It seems like it ignores all existing centroids, and adds to
areas which were previously missing them ?
Thanks!
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
