[GRASS-user] Weird results with r.sun
Odoardo Zecca
odoardo.zecca at gmail.com
Fri Oct 12 02:24:03 EDT 2007
Hi all,
running r.sun on a mountain area with time=8 and day=1, I got negative
values for the diffuse radiation fraction.
I even get negative global radiation!
Where am I wrong?
| Layer: 1_8_d Date: Fri Oct 12 07:53:50
2007 |
| Mapset: zodoardo Login of Creator:
zodoardo |
Valledaosta |
| DataBase:
//media/sda7/zodoardo/cartografia/grassdb |
| Title: ( r.sun solar model output
| timestamp:
none |
| Type of Map: raster Number of Categories:
255 |
| Data Type:
FCELL |
| Rows:
864 |
| Columns:
1290 |
| Total Cells:
1114560 |
| Projection: UTM (zone
32) |
| N: 5096987.5 S: 5032187.5 Res:
75 |
| E: 422587.5 W: 325837.5 Res:
75 |
| Range of data: min = -18.926418 max = 53.797997
| Data
Source: |
| Data
Description: |
| generated by r.sun
Comments: |
| Day [1-365]:
1 |
| Local (solar) time (decimal hr.): 8.0000
| Solar constant (W/m^2):
1367 |
| Extraterrestrial irradiance (W/m^2): 1412.689562
| Declination (rad): -0.401581
| Latitude min-max(deg): 45.4214 - 46.0199
| Sunrise time (hr.): 7.74
| Sunset time (hr.): 16.26
| Daylight time (hr.): 8.52
| Solar altitude (deg): 2.1959
| Solar azimuth (deg): 127.0877
| Linke turbidity factor: 3.1
| Ground albedo: 0.200
| r.sun -s elevin="DEM" aspin="DEM_asp" slopein="DEM_sl" lin=3.1alb=0\ |
| .2 beam_rad="1_8_b" diff_rad="1_8_d" refl_rad="1_8_r" day=1 step=0.5\
time=8 |
| Layer: 1_8_g Date: Fri Oct 12 08:20:06
2007 |
zodoardo |
Valledaosta |
| DataBase:
| Title: ( 1_8_g
| timestamp:
none |
255 |
| Data Type:
FCELL |
| Rows:
864 |
| Columns:
1290 |
| Total Cells:
1114560 |
32) |
75 |
75 |
| Range of data: min = -10.351157 max = 327.495667
| Data
Source: |
| Data
Description: |
| generated by r.mapcalc
Comments: |
| 1_8_b + 1_8_d +
1_8_r |
Thanks in advance for your help.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20071012/9fe64b26/attachment.html
