[GRASS-user] grass6.4 develbrunch revision 32726: undefined reference to `G_no_gisinit'
Michael Barton michael.barton at asu.edu
Tue Aug 12 14:11:23 EDT 2008
On Aug 12, 2008, at 11:06 AM, Markus Neteler wrote:
> On Tue, Aug 12, 2008 at 6:30 PM, G. Allegri <giohappy at gmail.com>
> wrote:
>> Noway.
>> Even switching to develbrunch I receive the same error:
>> usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
> You need to recompile the GRASS plugin, too.
> Also QGIS, if you use. And the GRASS-R interface...
> Essentially everything, which uses the GRASS libraries.
> (we backported to 6.4.svn a method to avoid that outdated GRASS
> libs are picked up, this AFAIK requires a recompilation of the
> depending
> libraries and programs).
Does this require all new frameworks on the Mac?
Michael
