[GRASS-user] grass6.4 develbrunch revision 32726: undefined
reference to `G_no_gisinit'
G. Allegri
giohappy at gmail.com
Wed Aug 13 13:30:56 EDT 2008
Thanks for the tips. Just a question: why gdal recompiling is needed?
Is the version changed?
2008/8/12 Michael Barton <michael.barton at asu.edu>:
> On Aug 12, 2008, at 11:06 AM, Markus Neteler wrote:
>> On Tue, Aug 12, 2008 at 6:30 PM, G. Allegri <giohappy at gmail.com> wrote:
>>> Noway.
>>> Even switching to develbrunch I receive the same error:
>>> usr/local/lib/libgdal.so: undefined reference to `G_no_gisinit'
>> You need to recompile the GRASS plugin, too.
>> Also QGIS, if you use. And the GRASS-R interface...
>> Essentially everything, which uses the GRASS libraries.
>> (we backported to 6.4.svn a method to avoid that outdated GRASS
>> libs are picked up, this AFAIK requires a recompilation of the depending
>> libraries and programs).
> Does this require all new frameworks on the Mac?
> Michael
