[GRASS-user] problems with ps.map outputs
Maciej Sieczka
tutey at o2.pl
Thu Aug 14 09:49:37 EDT 2008
Tom Russo pisze:
> <hamish_b at yahoo.com> wrote:
>> How about Inkscape or Scribus?
>> http://www.inkscape.org/
>> http://www.scribus.net/
> Both of these are cool programs, and if one could get ps.map's output into
> them they'd be great choices for tweaking map presentation. But neither is
> actually able to import a PDF (or even PostScript) map for editing.
> Scribus can import a PDF of text and allow you to edit it. It can't do much
> with the graphics, though.
> Inkscape can do a great deal with the graphics if you can get the data
> imported. But it can't read PDFs or postscript directly. Inkscape has some
> script that tries to use ghostscript to convert the document to an Adobe
> Illustrator document and then import that, but every time I've tried it it
> fails. As far as I could tell, it was because the ghostscript ps-to-ai deal
> didn't work properly on ps.map's generated postscript.
> Have you actually had success with either of these programs?
Tom,
I also had problem with Inkscape in past, but I just checked 0.46 stock
Debian testing package and it rocks now. See my previous message in the
thread.
Maciek
Maciej Sieczka
www.sieczka.org
