[GRASS-user] r.in.gdal ecw
Martin Landa
landa.martin at gmail.com
Tue Aug 19 11:25:11 EDT 2008
2008/8/19 Silvia Simoni <silvia.simoni at ing.unitn.it>:> Hi,
> I'm running GRASS 6.3 on MacOS X Leopard and have problems with importing
> ecw files. The r.in.gdal Help says that this format is supported and indeed
> it works as to the import phase. I can see 3 rasters for map.red, map.green
> and map.blue imported but I cannot visualize them either using d.rgb or
> r.composite and d.rast.
did you set region based on imported data?
g.region rast=map.red
d.rgb ...
Ciao, Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
