[GRASS-user] G_malloc: out of memory
Adam Dershowitz
adershowitz at exponent.com
Mon Dec 1 14:42:22 EST 2008
On Dec 1, 2008, at 11:14 AM, William Kyngesburye wrote:
> On Dec 1, 2008, at 12:46 PM, Adam Dershowitz wrote:
>>> I have 6.4 SVN binaries online now. Tested on Leopard so far. I
>>> also updated the build instructions in the source.
>>> A couple important changes from my previous binaries (the build
>>> instructions also reflect these changes):
>>> - It uses ActiveTcl 8.5 now for the TclTk GUI and NVIZ. This
>>> "aqua-fies" the TclTk GUI. The X11 TclTk is not bundled now and
>>> not needed.
>>> - It uses up-to-date wxPython binaries, even on Leopard. Starting
>>> with wxPython 2.8.8, it can install to be used with the Leopard
>>> system Python 2.5 as well as the python.org Python. This may
>>> interfere with the wx gui in GRASS 6.3, but it's not as well
>>> developed anyways.
>> I downloaded this. So far the basics seem fine, but I get an error
>> when I try to use nviz. The error is below:
>> Do I have to separately install a new version of TclTK? I have
>> both whatever is installed with the default 10.5.5, and I also use
>> MacPorts and I have tcl 8.5.5 and tk 8.5.5 installed from Macports.
>> Do I need to install something else? Or is nviz just looking in
>> the wrong place and needs to get pointed in the right direction?
> Yes. It is mentioned in the readme.
> The GUI can use any TclTk, but NVIZ and v.digit require the TclTk
> 8.5 Aqua framework (ActiveTcl or compiled from source).
> OSX 10.5 only has TclTk 8.4 Aqua. There are problems with this
> version.
> I'm not sure about Macports, but I think that's an X11 TclTk.
Ooops. Sorry I missed the readme.
I checked and by default the Macports Tk is X11. But there is a flag
to build it for aqua (the flag is just +quartz) and that in term
passes the "--enable-aqua" flag to the tk build. It worked fine to
build. And now when I run Grass 6.4 the look is different, so clearly
it was using the X11 version, and now is using the aqua version. But
I still get the same error that I did before.
I think that it is correctly building Tk for aqua, but it not
generating a framework, and NVIZ seems to want it located in that
specific location as a framework. Does NVIZ do something a little
unusual about finding the path? Or does Tk do something unusual. I
have looked at the portfile (build instructions essentially) for Tk
and it looks like it is just putting that extra flag in place and not
doing much else. So I think that it is pretty much identical to
building with default settings from source.
--Adam
