[GRASS-user] d.rast.edit does not save edited map although Save
button is pressed
georgew
gws293 at hotmail.com
Mon Dec 15 14:31:15 EST 2008
thanks Glynn, here is what I am doing. After I type the command two new
windows open up: one a grid with a faint outline of the input raster maps,
the other what I consider to be a navigation window, to help displaying on
the grid the area to be edited.
I want to extend the track21_raster map line, a walking track. So I click on
the cell nearest to the last colored cell in the grid and enter the two
category values I have, in the bottom grid display boxes: one called value
(I enter a 1, the track segment value), the other aspect (I enter the
elevation, 640) then press enter. (There is a third box called also Value,
which I leave blank as I don't know what to place there!).
A new whitish cell is created. I repeat the process for a few cells then
save, but nothing is saved. The output map is identical to the input. The
following is displayed in the terminal:
WARNING: Raster map <tmp.d.rast.edit> not found
WARNING: <tmp.d.rast.edit> nothing removed
Is it possible that the new cells are painted in white therefore invisible
when seen in the display? I have not found a way to change their color.
Any further help you can give will be most welcome.
By the way I am on GRASS 6.3 and Ubuntu 8.04.
Glynn Clements wrote:
> georgew wrote:
>> Hi, I must be doing something wrong with the following:
>> d.rast.edit input=track21_rast at PERMANENT output=track21_edited_rast
>> aspect=contours21_rast at PERMANENT width=640 height=480 size=12 rows=200
>> cols=200 --overwrite
>> The edited data is not saved in the output map which remains identical to
>> the input map, although I pressed the Save button in the grid display.
>> All the data is in my home directory (and anyway using "sudo
>> d.rast.edit"
>> results in "d.rast.edit not found" error.)
>> Any clues what I might be doing wrong. ?
> What is the nature of the editing? If the only changes are setting
> specific cells to null, that's one thing which d.rast.edit can't
> handle. You would need to set the cells to some unused value then
> subsequently change them to nulls with r.null.
> If you're changing cells to non-null values, then I don't know what
> the problem is.
> Glynn Clements <glynn at gclements.plus.com>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/d.rast.edit-does-not-save-edited-map-although-Save-button-is-pressed-tp21011399p21020243.html
Sent from the Grass - Users mailing list archive at Nabble.com.
