[GRASS-user] Re: Command line (bash)
for Windows grass?
Gerald Nelson
gnelson at uiuc.edu
Sun Feb 17 16:07:18 EST 2008
You'll need to delete the reference to bash in the first line of your scripts, and start grass by executing /c/grassxx/bin/grass63 where grassxx is the name of your grass version. And you may need to edit grass63 as well to make sure it uses unix style paths. I've been able to run some bash scripts written for a unix box in wingrass without too much trouble.
Jerry
---- Original message ----
>Date: Sun, 17 Feb 2008 21:25:59 +0100
>From: WolfgangZ <wollez at gmx.net>
>Subject: [GRASS-user] Re: Command line (bash) for Windows grass?
>To: grass-user at lists.osgeo.org
>Jonathan Greenberg schrieb:
>> I've switched to using the mingw version -- msys comes with a command
>> line "sh.exe", but I can't seem to a) boot grass using it, and b) and
>> suspicious it won't be able to run bash scripting (sh is not the same as
>> bash, correct?)
>> --j
>can you please report in detail what software versions you use! grass,
>msys, mingw, ...
>Otherwise it is really hard to figure out your problem.
>Wolfgang
>_______________________________________________
>grass-user mailing list
>http://lists.osgeo.org/mailman/listinfo/grass-user
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
