[GRASS-user] d.rast.edit does not save edited cells (?)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Thu Feb 21 06:25:21 EST 2008
Ohhhh! I got it!
It's the "*" I am using. With the value "66" for example it worked!
But why not with "*". It's a perfect tool if one needs to manually
correct some details.
And why not having a magic "key" with which one can "fly" over pixels
with the mouse pointer and assign new values instead of "countless
clicks".
I know many occasions were this is necessary to be done and there is no
fastest and more precise method than just doing it by hand.
Cheers ;-)
On Thu, 2008-02-21 at 12:14 +0100, Nikos Alexandris wrote:
> No errors!
> Hmmm... ! I though that it works as follows (and did):
> 1. Open a raster and give a name for the new raster (open a raster with
> areas, all having the same value "5")
> 2. edit, save, exit (I "erased lots of pixels from various areas by
> assigning the * -- that is NULL, no?)
> 3. load the NEW raster and see the changes (I load the NEW raster and it
> is identical with the old map)
> Is it the * values? Effects take place with non-NULL values maybe?
> > > I am trying to make use of this amazing tool but whenever I "save" &
> > > "exit" & "d.rast" my new raster it looks like the old one!
> > > Is there a secret setting?
> > No. You are looking at the new map (output=), not the original
> > (input=), right? If you're trying to edit a map "in place" (i.e. input
> > and output are the same map), I don't think that's been tested.
> > Are there any error messages or warnings displayed in the terminal?
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080221/e0911400/attachment.bin
