[GRASS-user] gpsbabel and garmin_txt, v.in.garmin, v.in.gpsbabel - with garmin etrex
Philipp Steigenberger userlist at online.de
Mon Feb 25 06:29:27 EST 2008
Hamish,
thanks for helping!
Im very sorry that I confused you.
The #ID 25 is just a comment to tell you that the third column contains
the ID.
I tried a little more to get my data from GPS. No that I installed the
newest version of gpsbabel it also works that I get the aptitude-values
using v.in.gps.babel. My goal is to generate a DTM from this data, so
I'm happy now. - And - as you - I am also to busy to spend more time on
this.
sincerly
Philipp
Hamish schrieb:
> Philipp Steigenberger wrote:
>>> v.in.garmin port=/dev/ttyUSB0 -t -p out=vingarmin_gpstrans_tracks
>>> GPStrans (ASCII) - Version 0.39
>>> Copyright (c) 1995 by Carsten Tschach (tschach at zedat.fu-berlin.de)
>>> Linux/KKJ mods by     Janne Sinkkonen <janne at iki.fi> (1996)
>>> Copyright (c) 2000 German Grid by Andreas Lange
>>> <andreas.lange at rhein-main.de>
>>> Copyright (c) 1998,2000 Mayko-mXmap mods by Matthias Kattanek
>>> <mattes at ugraf.com>
>>> Copyright (c) 2001 Development by Joao Seabra-CT2GNL
>> <seabra at ci.AAC.uc.pt>
>>> Receiving Tracks...
>>> ERROR: Only DDD coordinates currently supported. [DMS]
> see the v.in.garmin help page about running 'gpstrans -s' first to set
> output as DDD.
> I have found that gpstrans can sometimes be buggy (tracks offset by 1
> relative to timestamp), so you may prefer another solution if you need
> exact timestamps.
>>> v.in.garmin port=/dev/ttyUSB0 -t -p -u
>> out=vingarmin_gardump_tracks
>>> Receiving Tracks...
>>> --->  with v.out.ascii I get this format:
>>> 4416848.824221|5359764.2067414|25 #id=25
> The last attribute is not being split into two columns for some reason.
> What model Garmin and what version of gardump do you use?
> can you send a few line sample of the result of running gardump from
> the command line to the list as an attachment?
> do you have an idea what the #id= means?
> I am rather too busy right now to spend much time on this, or even to
> monitor the mailing list closely, but I hope someone else might be able
> to have a look and see the problem. If not, please file a bug report
> with as much information and sample data as you can and I'll eventually
> get to it. Or jump into the shell script yourself- it's a pile of sed
> and awk processing.
> Hamish
>       ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
