[GRASS-user] gpsbabel and garmin_txt, v.in.garmin,
v.in.gpsbabel - with garmin etrex
Hamish
hamish_b at yahoo.com
Mon Feb 25 15:37:58 EST 2008
Philipp Steigenberger wrote:
> I tried a little more to get my data from GPS. No that I installed
> the newest version of gpsbabel it also works that I get the
> aptitude-values using v.in.gps.babel. My goal is to generate a
> DTM from this data, so I'm happy now.
note GPS positions will be about an order of magnitude less accurate in
the vertical than in the horizontal, don't be surprised if a standard
handheld GPS differs in the vertical by +-20m. also note that the
elevation given is height above the WGS84 geoid, not above sea level.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
