[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri
giohappy at gmail.com
Tue Feb 26 06:15:03 EST 2008
Thanks Michael. It works. I thought I had already tried this way...
this time it worked correctly checking the "Output legend for GIS
Manager (for scripting use only)".
2008/2/26, Michael Barton <michael.barton at asu.edu>:
> On Feb 25, 2008, at 4:42 PM, G. Allegri wrote:
> ec
> > Michael, I posted an answer at 5.42 pm...
> > I attach it again.
> > You're right Michael. Sorry for not being exhaustive.
> > I'm doing test on Kubuntu 7.10
> > Grass: 6.3.0 RC5
> > wxwidgets: 2.8.4.0
> > python: 2.5.1
> > I create a thematic vector map (from the gui). It's a point layer. I
> > ask to use graduated_points on a double type attribute.
> > Execution failed: 'd.vect.thematic map=topsoil_completo at tesi
> > type=point column=Ece themetype=graduated_points themecalc=interval
> > size=9 maxsize=25 nint=10 colorscheme=blue-red --q'
> > GRASS_INFO_ERROR(16631,1): *** You must open a display monitor ***
> I've run some tests and can tell you what you need to do to avoid the
> error when creating a thematic layer in the GUI Layer Manager.
> However, we will probably need to make a custom thematic module
> rather than depend on the autogenerated GUI in this case.
> You need to go to the Misc tab and check the box "Output legend for
> GIS Manager (for scripting use only)".
> This should create the thematic map without also generating the xmon
> error. However, it will not creating a legend automatically. This
> needs to be created through custom programming, as is done with TclTk
> GUI.
> I think we should wait to create the custom thematic module, however,
> until the C version of this is done (currently functional for areas,
> but not yet for points or lines). The current version
> (d.vect.thematic) is a bash script.
> I hope this is helpful. Thanks for testing the wxPython GUI>
> Michael
> > The same error raises if I launch it from commandline both in
> > wxgrass and tcltk.
> > Again, I loose control on the GUI and got to kill it.
> > In Grass tcltk this command works correctly:
> > d.vect.thematic -s map=topsoil_completo at tesi type=point column=Ece
> > layer=1 icon=basic/circle size=9 maxsize=25 nint=10
> > pointcolor=255:0:0 linecolor=0:0:0 startcolor=255:0:0
> > endcolor=0:0:255 themetype=graduated_points monitor=none
> > themecalc=interval colorscheme=blue-red
