[GRASS-user] wxpython gui: d.vect.thematic raises error
G. Allegri
giohappy at gmail.com
Tue Feb 26 06:17:16 EST 2008
> basically snapping is done when new feature is written (snapping on
> the fly could be implemented using wxPython functionality). If you
> want to enable snapping to background vector map objects, set up
> background map in digitization settings. The behaviour is the same,
> snapping is done when feature is written not on the fly. Can be
> reported as a wish.
I will put in the wish. I imagine you're using the v.edit system to do
snapping now... I'll try to figure out how to manage on-the-fly
snapping with wpython.
