R: [GRASS-user] linking different tables to one vector file...
Aldo Clerici alcl01 at unipr.it
Tue Jan 15 06:06:30 EST 2008
may be the attached scheme is of some help.
Greetings
A.Clerici
-----Messaggio originale-----
Da: grass-user-bounces at lists.osgeo.org
[mailto:grass-user-bounces at lists.osgeo.org] Per conto di Martin Landa
Inviato: martedì 15 gennaio 2008 9.03
A: Jaime Carrera
Cc: grass-user at lists.osgeo.org
Oggetto: Re: [GRASS-user] linking different tables to one vector file...
2008/1/15, Jaime Carrera <jaicarrerahdez at yahoo.com>:
> I wanted to ask if its possible to link different tables to a vector map
> with points, lines and areas (i.e link nodes to node_table, lines to
> lines_table and areas to area_table).
yes, it is possible. Vector map can be multi-layered. In your case
first sub-layer can contain points, the second lines, etc. You can
link different tables to sub-layers using v.db.connect. In your case
you just need to separate vector types to the different sub-layers.
Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
Type: application/pdf
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080115/58441027/Scheme-0001.pdf
