[GRASS-user] creating new geometry from pre-existing lines and
points
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Jan 30 16:36:49 EST 2008
On Wed, 2008-01-30 at 19:32 +0200, David Epstein wrote:
> Hi everyone,
> First--I want to thank everyone on this list. I've installed a lot of
> new tools in the last month (including a new OS, ubuntu) and got up and
> running very fast because of help received here. Thank you again!
> Second--another question (of course). I have a vector (polygon) layer
> and there is a hole (no surface). I want to turn that hole into a
> polygon using the existing lines and points around it. I thought I could
> use v.digit for this but I did a very poor job. Perhaps there is a
> particular v.digit technique or another tool I should use?
I didn't tried it yet... (cause I need the islands in my work
currently!) but here is a "copy-paste" from the v.extract man page:
Remove islands from polygon map
v.extract in=map_with_islands out=maps_without_islands
list=1-99999
# and/or
v.extract -d in=map_with_islands out=maps_without_islands
> Also (and this relates to a previous question of mine) if I have
> imported a postGIS vector layer via v.in.ogr, does that create a
> permanent link so that edits via v.digit are then written back to the
> SQL database? Or do I need to somehow tell it to update?
> thank you again,
> -david
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080130/51e0a477/attachment-0001.bin
