[GRASS-user] Building wxgrass vdigit
Glynn Clements
glynn at gclements.plus.com
Thu Jan 31 03:24:36 EST 2008
Craig Leat wrote:
> > I'll try building the whole of GRASS again, just in case I missed
> > something and will report back. Thanks for the help so far.
> Hi Glynn
> I have just completed the make distclean, ./configure, make sequence
> while ignoring the instructions in Martin's README. Configure and make
> didn't report errors, however I'm still unsuccessful with building vdigit:
> GRASS 6.3.svn
> (msunduzi_lo31):/usr/local/src/grass_trunk_28012008/bin.i686-pc-linux-gnu
> > wxgrass
> GRASS 6.3.svn
> (msunduzi_lo31):/usr/local/src/grass_trunk_28012008/bin.i686-pc-linux-gnu >
> WARNING: Digitization tool is disabled (No module named
> grass6_wxvdigit). Detailed information in README file.
Once you've built GRASS, build vdigit manually. The 6.3RC* Makefiles
don't know that the vdigit directory is there, so they won't try to
build it.
Also, I think that you will need to have used --with-python when
configuring GRASS.
