[GRASS-user] dyld: Library not loaded
Dwight Needels
needels at translucida.com
Thu Jul 17 22:38:50 EDT 2008
on 7/17/08 10:23 PM, William Kyngesburye at woklist at kyngchaos.com wrote:
> On Jul 17, 2008, at 8:53 PM, Dwight Needels wrote:
>> I do not have a specific need for GPSBabel 1.3.5. I deleted the
>> installer
>> receipt for your GRASS version and reinstalled 6.3.0-1 [same
>> problem]. I
>> then downloaded and installed your 6.3.0-2 [same problem]. I also
>> tried
>> commenting the gpsbabel path out of my $PATH statement [same problem].
>> When I view the contents of your GRASS package, the version of
>> gpsbabel has
>> a modification date of 7/3/08 (8:15p). The version 1.3.5 from
>> gpsbabel.org
>> has a modification date of 5/4/08.
>> I only get the dyld library error when I use GPSBabel from within
>> GRASS
>> without an explicit path; it works fine when I use an explicit path
>> to the
>> gps.babel.org version or when I use a fresh (non-GRASS) Terminal
>> session.
> It's possible some version is first in your shell PATH somewhere.
> With GRASS running, whichever version is giving you problems, type in
> the Terminal window:
> type gpsbabel
> This will tell you which binary of gpsbabel is used by default.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
GRASS 6.3.0 (Meriden_GIS):~ > type gpsbabel
gpsbabel is hashed (/Applications/GRASS-6.3.app/Contents/MacOS/bin/gpsbabel)
Thanks, -Dwight
