[GRASS-user] Re: import a folder full of shapefiles and reproject
on-the-fly?
Maciej Sieczka
tutey at o2.pl
Thu Jul 24 04:42:02 EDT 2008
Tim Michelsen pisze:
> Maciej Sieczka wrote:
>> Moritz Lennert wrote:
>>> So, normally, if you don't give a layer all the shapefiles in the
>>> directory (dsn=) will be imported.
>> Note this loads the Shapefiles as *layers* (in the GRASS meaning of
>> it) of a single output vector map. Not necessarily what one might
>> want.
> That means that they would get imported as patched tiles?
Not exactly - the geometry would be in a single vector map, but each
ex-tile would have a separate attribute table and categories of features
in each ex-tile would not be unique cross-layer. Read about the layer
concept in the GRASS manual.
> Here is my workflow
> 1) import all landcovers in the UTM location=> v.in.ogr 2) patch all
> landcover tiles => v.patch in=list_of_tiles out=tiles_all 3) import
> the tiles_all into the lat/lon location
That's different than what you wrote initially - you wrote you need to
reproject first, and then import all reprojected tiles into one location.
Given the above workflow, mind that each UTM zone is a different CRS
actually. Do all your shapefiles fit into a single UTM zone?
> Can this be done more efficiently?
You can patch and reproject multiple shapefiles with ogr2ogr alone. See
it's manual. Then import into GRASS location in a single v.in.ogr step.
>>> You will, however, need a loop for the v.proj step...
>> ogr2ogr is more convenient than going through a temporary location
>> creation, Shapefile import and reprojection with v.proj, IMHO. Much
>> less work.
> If I want to change the projection of the lat/lon location with
> g.setproj do I also need to reporject all layers inside that
> location?
I don't quite understand what you mean.
Maciek
Maciej Sieczka
www.sieczka.org
