[GRASS-user] Re: Any freely available topographical maps for
(South-) Germany ?
WolfgangZ
wollez at gmx.net
Fri Jun 13 10:55:36 EDT 2008
Hamish schrieb:
> [r.in.wms]
> Hamish wrote:
>> no geotiff support. set format= to one of the above.
>> I tried in a WGS84 lat/lon loc:
>> g.region n=50:30N s=47:15N w=9E e=13:45E res=0:00:30
>> r.in.wms mapserver="$SERVER" layer=TK50
>> out=TK50_Bavaria format=png -g
>> it seemed to work, but I only got a blank map. Maybe you
>> will have better luck. Using "-g" I got a
>> "(c) Bayerische ..." in the image, without "-g" I didn't. shrug.
> Richard wrote:
>> I've never been able to decide whether "blank raster syndrome" in
>> r.in.wms is at the client or the server. In some cases, I guess it's
>> the server because things rectify themselves if you come back tomorrow.
> In this case I'm pretty sure it's the server. As above, in at least one set of blank images I see the (c) watermark which comes through ok. Also with r.in.wms you can look in the $LOCATION/wms_downloads/ dir and see the raw download images before any client processing. all blank.
>> In other cases, adjusting the region parameters - zoom in to a smaller
>> area, and use a finer resolution - fixes the problem.
> I took your suggestion and tried zooming in some. Success!
> I would note that earlier when I was getting the blank image I did check the bounds layer's capabilities to make sure I was not exceeding the bounding box. So it seems to be matter of scale, not bounding box.
> # LL/WGS84 location
> SERVER="http://www.geodaten.bayern.de/ogc/getogc.cgi?"
> g.region n=49:17N s=48:33N w=10:54:30E e=11:32:30E res=0:00:02
> r.in.wms mapserver="$SERVER" layer=UK500 out=UK500_Bavaria.3 format=tiff
> then you get a map of roads, place names, cities, etc.
> (format=tiff looks more detailed than 8bit png, but png is way more efficient for empty files. shrug)
> #zooming in more, DOP layer (2m aerial photo) looks good:
> g.region n=49:12:02N s=49:04:20N w=11:03:26E e=11:11:42E res=0:00:01
> r.in.wms mapserver="$SERVER" layer=DOP out=DOP_Bavaria format=tiff
> # and zooming even further the TK50 layer finally works
> # TK50 is a similar feature map to UK500, including contours
> g.region n=49:10:06N s=49:07:34N w=11:06:27E e=11:08:54E res=0:00:00.25
> r.in.wms mapserver="$SERVER" layer=TK50 out=TK50_Bavaria format=tiff
> So yes, zooming helps.
> The DOP layer draped over SRTM data would look very nice.
Yes the server provides only white images when less then 2 meter / pixel
resolution. I used a own written script which downloads the images with
some overlap to get rid of the copy right notice.
At least for the alps you can get elevation data with 1 arcsec from
http://www.viewfinderpanoramas.org/dem3.html#hgt
There was also some time ago a library to convert the data from the
"Top50" CDs that you can purchase for low money, but that is offline
again ;-( http://libmpr.origo.ethz.ch .
