[GRASS-user] removal of duplicate points
G. Allegri giohappy at gmail.com
Wed Mar 5 13:17:06 EST 2008
What's wrong with v.out.ascii? Couldn't you export and then remove duplicate
points by checking the coordinates? To avoid checking both X and Y, these
could be summed, so a single check would be enough.
giovanni
2008/3/5, Dylan Beaudette <dylan.beaudette at gmail.com>:
> Hi,
> I have some "squares" which are stored as polygons. When converting these
> to
> points (v.to.points) I am left with the 5 points (first and last point are
> duplicated) that define the corners of the "square".
> Is there a vector module (v.edit / v.clean) that could remove duplicate
> points? I would like to replace the manual operation with v.digit with
> something that can be scripted. Note that there are multiple "squares", so
> a
> simple v.out.ascii | head -4 | v.in.ascii  would be a little awkward.
> Ideas?
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080305/6174e312/attachment.html
