[GRASS-user] generalize a map of points
Wolf Bergenheim
wolf+grass at bergenheim.net
Sun Oct 19 16:46:00 EDT 2008
José María,
> If possible, I think it would be useful feature the following:
> - Where two labels overlap, comparing an attribute to decide which one stays
> For example: on a map of cities you can use the number of inhabitants.
> If the city "A" has more inhabitants than the city "B", maintaining
> the label of the city "A".
I have just now committed a change in v.label.sa that will do exactly
this. See the new overlap parameter. I would appreciate it if you could
test it, and give some feedback on how it is working for you.
Thank you,
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
