[GRASS-user] generalize a map of points
José María Michia jose.maria.michia at gmail.com
Mon Oct 20 09:01:22 EDT 2008
2008/10/19 Wolf Bergenheim <wolf+grass en bergenheim.net>:
> José María,
>> If possible, I think it would be useful feature the following:
>> - Where two labels overlap, comparing an attribute to decide which one stays
>> For example: on a map of cities you can use the number of inhabitants.
>> If the city "A" has more inhabitants than the city "B", maintaining
>> the label of the city "A".
> I have just now committed a change in v.label.sa that will do exactly
> this. See the new overlap parameter. I would appreciate it if you could
> test it, and give some feedback on how it is working for you.
> Thank you,
> --Wolf
Yes, I am doing the tests right now.
It's very good for me to working with you in some way. So, thank you.
José María
> <:3 )---- Wolf Bergenheim ----( 8:>
