[GRASS-user] Patching large numbers of vectors
Richard Chirgwin
rchirgwin at ozemail.com.au
Thu Oct 23 17:49:17 EDT 2008
There seems to be a problem in handling of large numbers of vectors.
I had a large number of buffered points to put together. The buffer
areas (with centroids added) were constrained by non-overlapping areas
to avoid errors later, after which I wanted to patch them together into
a single file. I used:
for i in `g.mlist vect pattern="Centroids*"`; do
v.patch -a -e input=$i output=patchfile --overwrite;
done
to do this.
For most vectors, everything works fine, but every now and again, the
patching process would report a problem (something like "error bug sidx
topo", it goes by in a flash and I haven't been able to work out how to
log the script outputs) with an individual vector. If, however, I
patched the vector manually (outside the script), it would work fine.
I suspect that because of the speed and huge number of vectors I'm
trying to put together, v.patch is having trouble finding the sidx file,
but really, I have no idea. Any thoughts?
Richard Chirgwin
