[GRASS-user] Problem with executing some type od queries (with
regular expresion parser)
Jarek Jasiewicz
jarekj at amu.edu.pl
Wed Oct 29 17:20:52 EDT 2008
Hi
Well, I thing I expect too much, but for now grass has been suprising me
(positively) on cooperation GRASS - POstgreSQL
I have a query which works well in PgAdmin:
SELECT cat FROM streams_coor WHERE link::text IN(
SELECT regexp_split_to_table(
(SELECT branch FROM links WHERE keyid='168'), E'\\.'))
the branch looks like this:
"89.88.166.169.168"
and result are:
148
150
161
168
157
If I try to use this query in gis.m "use sql query" field with proper
SQL syntax"
link::text IN(
SELECT regexp_split_to_table((
do not receive any error but also any result
so where is problem?
As far as I know GRASS simply send query to database and recive list of
cats as a result, so there could be the problem with parsing quotemarks
and escape marks in regular expresion?
regards
Jarek
