[GRASS-user] Problem with executing some type od queries (with
	regular expresion parser)
    Maris Nartiss
    maris.gis at gmail.com
    Thu Oct 30 05:48:37 EDT 2008
Hello Jarek,
please re-run Your gis.m with DEBUG=3
g.gisenv set=DEBUG=3
then redraw map and look into output pane for line:
D3/3: db_select_int()
D3/3:   SQL: SELECT cat FROM ...
and post result here.
Ignore other error messages, that will popup.
Maris.
2008/10/29, Jarek Jasiewicz <jarekj at amu.edu.pl>:
> Hi
> Well, I thing I expect too much, but for now grass has been suprising me
> (positively) on cooperation GRASS - POstgreSQL
> I have a query which works well in PgAdmin:
> SELECT cat FROM streams_coor WHERE link::text IN(
>    SELECT regexp_split_to_table(
>         (SELECT branch FROM links WHERE keyid='168'), E'\\.'))
> the branch looks like this:
> "89.88.166.169.168"
> and result are:
> 148
> 150
> 161
> 168
> 157
> If I try to use this query in gis.m "use sql query" field with proper
> SQL syntax"
> link::text IN(
>     SELECT regexp_split_to_table((
> do not receive any error but also any result
> so where is problem?
> As far as I know GRASS simply send query to database and recive list of
> cats as a result, so there could be the problem with parsing quotemarks
> and escape marks in regular expresion?
> regards
> Jarek
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
