[GRASS-user] v.trees.3d and gem
Gabriele N. gis.gn at libero.it
Sun Sep 14 11:17:40 EDT 2008
thanks, Hamish.
I did not understand how to install v.trees.3d with grass installed by the
binaries.
So I installed grass64 by source and I have tried in many ways but I was not
able to install v.trees.3d.
For example (into grass)
GRASS 6.4.svn (gb2):/usr/src/grass_addons > gem6
--grass=/usr/local/grass-6.4.svn/ -i v.trees3d.tar.gz
Uncompressing files...DONE.
ERROR: 'name' file not readable.
Program exited with an error (code -6). Operation aborted.
[Raster MASK present]
Or
gab a gab-laptop:/usr/src/grass_addons/v.trees3d$ sudo make
MODULE_TOPDIR=usr/local/grass-6.4.svn
Makefile:10: usr/local/grass-6.4.svn/include/Make/Module.make: No such file
or directory
make: *** No rule to make target
`usr/local/grass-6.4.svn/include/Make/Module.make'.  Stop.
hamish_b wrote:
> Gabriele wrote:
>> I installed gcc and now I have installed the build-essential package.
>> There is no package glibc-devel.
> Hi,
> could you point out for us where in the documentation that information is
> missing? Then we can add it and the next user to come along doesn't hit
> the same problem.
>> The error has changed:
>> /usr/src/gem-1.03/tools.c:546: warning: the use of `mktemp' is dangerous,
>> better use `mkstemp' or `mkdtemp'
>> gab a gab-laptop:/usr/src/gem-1.03$
> That's not an error just a warning message. The module should have still
> been built successfully.
> And for what it's worth, mktemp in the GEM code was replaced with mkstemp
> a year ago and the change is included in the GRASS 6.3.0 release.
> devs: I see that the iostream lib conditionalizes mkstemp() so mktemp is
> used for WinGRASS. So either iostream/ or GEM needs updating.
> Hamish
> grass-user mailing list
> grass-user a lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/v.trees.3d-and-gem-tp19473122p19481242.html
Sent from the Grass - Users mailing list archive at Nabble.com.
