[GRASS-user] Trouble with ESRI TIGER/LINE Files and Coordinate
System
Hamish
hamish_b at yahoo.com
Tue Sep 16 04:32:01 EDT 2008
Ryan Rosario wrote:
> I have downloaded several files from the ESRI TIGER/LINE database. The
> site claims that the files are in lat/lon NAD83 format. Perfect!
> I assume this would correspond to EPSG 4269 format.
> I import the shape file using v.in.ogr and then display the vector map,
> it is displayed in a region using some other format (huge numbers), and
> not in the lat/lon format I expected. The projection even reads "x,y"
> even though I selected lat/lon for the location:
> | Projection: x,y
> | N: -322776.48526848 S: -457156.35430172
> | E: 51189.38422193 W: -59948.35401544
> What is strange is that if I import this shape file into gvSIG, it reads
> the map perfectly fine, with the correct coordinate system.
> Since the file is in plain ol' lat/lon, it should display that way in
> GRASS.
> What am I missing??
> What could I be doing wrong?
can you check with ogrinfo what's *really* in the shapefile?
ogrinfo -ro -al mapname.shp
That will dump a huge amount of stuff to the terminal (^C to kill it)
but you should see LINESTRING with a comma separated list of coordinates.
Are those raw coordinates in lat/lon or ...?
what does the shapefile.prj look like?
I am not too familiar with gvSIG's capabilities; will QGIS load it and
show correct projection info and mouse-over coords on the bottom status
line?
Hamish
