[GRASS-user] Second try,
	run grass scripts as batch process in Windows
    Marco Pasetti
    marcopstt at gmail.com
    Thu Sep 25 03:31:21 EDT 2008
> Personally, I would prefer if we could avoid using Msys as a crutch. IMHO,
> people should be able to run their scripts in their native environment.
> This is why the best bet is probably to write scripts in Python.
right, I agree, actually.
so, reformulating:
1. write your GRASS batch commands using the DOS syntax and save them as a
.bat file in C:\my_grass_scripts\
2. open a GRASS command line
3. type: set PATH=C:\my_grass_scripts;%PATH%
4. launch the batch script directly from the command line
Marco
