[GRASS-user] v.digit mouse click emulation on macbook
gsi espm182 at gmail.com
Fri Apr 17 23:27:29 EDT 2009
On my MacBook (leopard) using the grass64-binaries provided by KyngChaos the
combination keys that you mention dont work as you said.
For instance, Command+click does not emulate the right click to close the
line and emulates the left key adding a node.
For instance, Option+ click does no emulate the middle click to undo a node
On the contrary,
two finger on the touchpad + click emulate the middle click to undo a node
A single click emulates de left click adding a node.
The problem remains: I cannot close any line or  boundary.
PS:tonight I am going to try the same issue on my iMac.
On Fri, Apr 17, 2009 at 6:42 PM, Hamish (via Nabble) <
ml-user+64140-103258653 at n2.nabble.com<ml-user%2B64140-103258653 at n2.nabble.com>
> wrote:
> gsi wrote:
> > > I can run v.digit (grass64) on my macbook but I cannot
> > > use it because I cannot find how to emulate the right and
> > > middle click correctly. Rigth click (two fingers on the
> > > touchpad + click) behaves like a middle click, and I cannot
> > > find any combination to emulate the right click.
> John wrote:
> > I believe that control-click and
> > option-click emulate the other buttons in X11, but you will
> > need to experiment. Did you try any modifier keys?
> on the bottom left of the mac keyboard there are 3 modifier
> keys- from left to right:  control, option, and command
> clicking while holding down the control button on the left
> emulates a left click (a no-op), clicking while holding down the
> middle of those keys (option) emulates a middle click, and
> clicking while holding down the right of those keys (command/
> old 'apple' key?) emulates a right-click.
> hth,
> Hamish
> grass-user mailing list
> grass-user at ...<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=2653874&i=0>
> http://lists.osgeo.org/mailman/listinfo/grass-user
>  This email is a reply to your post @
> http://n2.nabble.com/v.digit-mouse-click-emulation-on-macbook-tp2652267p2653874.html
> You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/v.digit-mouse-click-emulation-on-macbook-tp2652267p2654116.html
Sent from the Grass - Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090417/eb792b2c/attachment.html
