[GRASS-user] user/group permissions for accessing data on mounted
drive
Glynn Clements
glynn at gclements.plus.com
Sun Aug 16 00:33:21 EDT 2009
Tim Michelsen wrote:
> I have a question on the requirements GRASS has towards user/group
> permissions on linux:
> My data is stored on a vfat partition mounted by a Ubuntu Linux.
> The corresponding entry in the mount configuration file (/etc/fstab) goes:
> UUID=44FC-A7FD /media/daten vfat
> defaults,utf8,gid=46,fmask=111,umask=000 0 0
> group id 46 belongs to plugdev which contains all users that can mount
> drives.
> The rights shown by ls -l look like:
> drwxrwxrwx 5 root plugdev 32K 2009-03-02 20:01 transfer
> -rwxrwxrwx 1 root plugdev 0 2009-07-07 23:11 video.flv
> When I start GRASS trying to access the GRASS data base at
> /media/daten/grassdata it says "ERROR: MAPSET PERMANENT - permission
> denied" and the GUI would abort.
> Please inicate me how I need to set my permissions on the mounted drive
> that GRASS can use the data.
You must be the owner of the directory selected as the current mapset.
A FAT/VFAT partition mounted by root must be mounted with the uid=
option to set the owner.
Alternatively, you can disable the checks in the source code and
re-compile. The checks are in G__mapset_permissions and
G__mapset_permissions2 in lib/gis/mapset_msc.c. This isn't recommended
on a multi-user system, as it can result in a user inadvertently
creating directories which the mapset's owner cannot delete or rename.
