[GRASS-user] Re: Georectify problem
Michael Barton
Michael.Barton at asu.edu
Wed Dec 2 12:46:48 EST 2009
This is a conflict between what wxPython sees as the Python is it
supposed to use and what your systems sees as the proper Python to use.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Dec 2, 2009, at 10:43 AM, Adam Dershowitz, Ph.D., P.E. wrote:
> I just tried your 6.4 build and I noticed two things. 1) When I
> double click on it, I see this in the terminal:
> Rebuilding Addon menu...
> Python 2.5.4 found.
> But, if I try to switch to the non-default gui, here is what I get:
>> g.gui wxpython
> Traceback (most recent call last):
> File "/Applications/Grass/GRASS-6.4_Barton.app/Contents/MacOS/etc/
> wxpython/wxgui.py", line 55, in <module>
> import gui_modules.globalvar as globalvar
> wxpython/gui_modules/globalvar.py", line 62, in <module>
> import wx
> python/wx/__init__.py", line 45, in <module>
> from wx._core import *
> python/wx/_core.py", line 4, in <module>
> import _core_
> ImportError: dlopen(/Applications/Grass/GRASS-6.4_Barton.app/
> Contents/MacOS/etc/python/wx/_core_.so, 2): no suitable image
> found. Did find:
> /Applications/Grass/GRASS-6.4_Barton.app/Contents/MacOS/etc/python/
> wx/_core_.so: no matching architecture in universal wrapper
> While, when I run William Kyngesburye's build I see this in the
> terminal:
> Python 2.6.4 found.
> But, at the command line, if I just do python, I end up with Apple
> version 2.6.1. I will also ask about this on the macports list,
> which is very active.
> For what it is worth, I know that in the past, with 10.5, and
> Macports installed I was able to run the wxpython version, but I
> can't seem to get it to work now.
> --Adam
> On Dec 2, 2009, at 9:11 AM, Michael Barton wrote:
>> If you have a second python and it is in your python path, you'll
>> have trouble. Do you know what the Macports "python_select" script
>> does?
>> You really don't need to install any extra Python because your Mac
>> already comes with Python 2.6, the most up-to-date of the 2.x
>> series. It should not be necessary to run anything downloaded from
>> MacPorts as any Python app should use the system Python unless it
>> needs an earlier version. If MacPorts is installing 2.3 or 2.4 this
>> could be a pretty big headache since GRASS requires at least 2.4
>> and possibly 2.5 or above to run its wxPython GUI (we've tried not
>> to break 2.4 compatibility but I haven't tested it). I've heard of
>> other people having trouble with conflicts from MacPorts. I uses to
>> use Fink but ran into some of the same issues. And by now I don't
>> really need it since many applications are now available on the Mac
>> in a more native way. You might try getting rid of the MacPorts
>> Python and see if GRASS run--and if MacPorts Python apps still run.
>> Michael
>> C. Michael Barton
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>> On Dec 2, 2009, at 10:00 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>>> I do have python installed as I have a bunch of things installed
>>> with macports and some of them depend on it and so installed it as
>>> part of the builds. So I can't really get rid of it. But, as
>>> part of macports, I do have python_select, which is a small port
>>> that allows me to switch which python is active and I am currently
>>> using the Apple installed Python 2.6, not one of the Macport
>>> installed versions. So I don't think that is the problem....?
>>> I am downloading one of your builds to test out right now.
>>> Thanks,
>>> --Adam
>>> On Dec 2, 2009, at 8:53 AM, Michael Barton wrote:
>>>> Did you install Python yourself? If so, you will need to get rid
>>>> of it. I know how to do so with 10.5, but am not sure of 10.6.
>>>> William might be able to offer guidance on this.
>>>> If you did not install a separate Python, I'm not sure what the
>>>> problem is. But you can try one of my builds. They work with Snow
>>>> Leopard on at least one student machine I know of. I've posted
>>>> very recent binaries for 6.4, 6.5, and 7.0.
>>>> http://www.public.asu.edu/~cmbarton/files/grass_mac
>>>> Michael
>>>> C. Michael Barton
>>>> Change
>>>> Phone: 480-965-6262
>>>> Fax: 480-965-7671
>>>> On Dec 2, 2009, at 9:44 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>>>>> Sorry, Mac 10.6.2 using William Kyngesburye's binary builds.
>>>>> --Adam
>>>>> On Dec 2, 2009, at 8:35 AM, Michael Barton wrote:
>>>>>> What OS platform?
>>>>>> Michael
>>>>>> C. Michael Barton
>>>>>> Change
>>>>>> Phone: 480-965-6262
>>>>>> Fax: 480-965-7671
>>>>>> On Dec 2, 2009, at 9:34 AM, Adam Dershowitz, Ph.D., P.E. wrote:
>>>>>>> I did try it, but I can't currently get it to run. My guess
>>>>>>> is that it is an issue of the current built of GRASS that I am
>>>>>>> using (6.4 RC5-3 on a 64 bit machine):
>>>>>>> g.gui wxpython
>>>>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/
>>>>>>> gui_modules/globalvar.py", line 59, in <module>
>>>>>>> import wx
>>>>>>> File "/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/
>>>>>>> import _core_
>>>>>>> ImportError: dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/
>>>>>>> etc/python/wx/_core_.so, 2): no suitable image found. Did find:
>>>>>>> _core_.so: mach-o, but wrong architecture
>>>>>>> --Adam
>>>>>>> On Dec 2, 2009, at 6:47 AM, Michael Barton wrote:
>>>>>>>> Important to note that this will not work with Windows, since
>>>>>>>> Windows doesn't run x11 unless you the Cygwin unix emulator.
>>>>>>>> Have you tried georectification with the new wxPython GUI?
>>>>>>>> Michael
>>>>>>>> On Dec 1, 2009, at 11:20 PM, grass-user-
>>>>>>>> request at lists.osgeo.org wrote:
>>>>>>>>> Date: Wed, 02 Dec 2009 15:01:23 +1100
>>>>>>>>> From: Richard Chirgwin <rchirgwin at ozemail.com.au>
>>>>>>>>> Subject: [GRASS-user] Re: Georectify problem
>>>>>>>>> To: grass-user at lists.osgeo.org
>>>>>>>>> Message-ID: <4B15E693.1010909 at ozemail.com.au>
>>>>>>>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>>>>>>>> Adam,
>>>>>>>>> If all else fails, work with a command line process ... I've
>>>>>>>>> never had
>>>>>>>>> happy experiences with the purely GUI rectification.
>>>>>>>>> i.group (groupname) (mapname)
>>>>>>>>> i.target (groupname) Target_Location Target_Mapset
>>>>>>>>> d.mon X0
>>>>>>>>> i.points (groupname) - this launches the GCP capture GUI
>>>>>>>>> (old style,
>>>>>>>>> X-windows but it works!)
>>>>>>>>> i.rectify (groupname) extension="something"
>>>>>>>>> order=(polynomial order)
>>>>>>>>> RC
>>>>>>>> _______________________________________________
>>>>>>>> grass-user mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
