[GRASS-user] Display thematic vector map - WinGRASS 6.3 (Vista)
    Ken Brookes
    ken_brookes at hotmail.com
    Fri Jan  2 16:03:55 EST 2009
Hello
I'm a GRASS GIS novice and have recently downloaded and successfully installed GRASS 6.3.0 directly onto MS-Windows Vista. I have been playing with the GIS manager GUI and have run into a problem trying to create thematic Vector maps and display them in the map display. I am using the North Carolina data set (example data set provided) and a variety of vector maps to try and create graduated color, point and line maps to get a feel of how it works. I have been adding the thematic layer and specifying all the parameters correctly in the GUI. The actual binning of the numeric data is occurring properly because a new window will pop-up with the correct legend for the parameters specified, however nothing will display in the map display window. I do get a message in the command line shell saying "No such monitor exists 'PNG' ". I've tried to run d.vect.thematic through the command line shell and get an error saying "must open display monitor". I'm not sure what the problem is. Can anyone help?
Thanks
K. Brookes
Toronto, Canada
_________________________________________________________________
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090102/24006c00/attachment.html
