[GRASS-user] r.surf.contour------G_malloc() no response
Markus Neteler
neteler at osgeo.org
Wed Jan 28 02:44:28 EST 2009
On Wed, Jan 28, 2009 at 8:30 AM, Mohammed Rashad <rashadkm at gmail.com> wrote:
> i am using r.surf.contour module and it takes long to respond. i have a
> large map.
Please post the output of
g.region -p
Which operating system are you using?
Markus
> But when i do v.to.rast goes fine after v.digit.
> but r.surf.contour generates
> G_malloc() errors when run after a long time.
> I wan to create a digital elevation model.
> i created the vector from digitising with raster backdrop and
> corrected vectors with v.build. The digitised vector from v.digit was also
> good when displayed.
> so i run v.to.rast module and the vector map got rasterised properly.
> now i want to run r.surf.contour and create an elevation map. when run
> modulw with proper parameters (input=rasterised map) it runs ok. After a
> long time it exists with some errors as:
> G_malloc() and some other errors and warnings. i have a plenty of memory as
> 512MB ram and good AMD processor.
> please help me if anyone can.
> Mohammed Rashad.K.M
> +919605476742
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
