[GRASS-user] Re: Error 3 and messages r.in.gdal
stephen sefick ssefick at gmail.com
Thu Jul 9 10:34:30 EDT 2009
I still don't understand what I am doing wrong.  I tried to set the
resolution to a smaller grid size and now the map won't display at
all.  First did the data survive the import with the gdal errors?  I
don't know all though it looks like it.  And now that I have a patched
region I can't see my beautiful reliefs for delineating stream
channels (I am a Stream Ecologist trying very hard to get stream
orders calculated).  agian Thank you for all of your help.
Stephen Sefick
On Thu, Jul 9, 2009 at 9:07 AM, Nikos
Alexandris<nikos.alexandris at felis.uni-freiburg.de> wrote:
> stephen sefick wrote:
>> Also r.patch returns what looks like a green to yellow blob of the
>> correct looking region, but without the resolution of the original
>> elevation maps (projected separately).  I am sure that I am missing
>> something rather easy.  Sorry for the repeated questions-  this is how
>> I learned R and I hope you folks will tolerate me whle I learn GRASS.
>> thanks
> Stephen,
> if you haven't done so already, it sure is useful to start from the
> manuals [1]. The "Raster data processing in GRASS GIS" section in the
> manual [2] should make several raster-aspects clear.
> As far as it concerns the "resolution": most of grass' modules will
> operate on the "current" defined (geographic) extent and resolution
> which you can check/set with g.region.
> Kind regards, Nikos
> [1] http://grass.osgeo.org/grass64/manuals/html64_user/index.html
> [2] http://grass.osgeo.org/grass64/manuals/html64_user/rasterintro.html
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
								-K. Mullis
