[GRASS-user] v.out.ogr to KML ERROR 1: Latitude is invalide
    Hamish
    hamish_b at yahoo.com
    Fri Jun 19 10:01:04 EDT 2009
maven wrote:
> First I create location :g.proj -c georef=d:/swilAlphaTIFF.tif
> datumtrans=0 location=newlocationthen import it
> to the new location: get four raster maps(it has three
> band),I composite them and then transfer the composted
> raster to vector,then extract each category to a vector,one
> of them is named bule.
> Then I start to covert the projection.I
> creation new epsg4326 location: then "v.proj input=bule
> mapset=PERMANENT dbase=D:\GrassDataBase output=newblueBut
> when I display the newblue it is blank,just like the
> projection is not matched......
what does 'v.info newblueBut' say from within the WGS84 lat/lon location?
what does 'g.region -p' say from the lat/lon location?
what does 'g.region -l' say from the UTM location?
maybe you just need to do "g.region vect=newblueBut" to reset the zoom
to match the data extent?
Hamish
