[GRASS-user] Determine surface areas
Markus Metz markus.metz.giswork at googlemail.com
Fri Mar 6 13:28:46 EST 2009
Nikolaus Arnold wrote:
> Finally got it.
> Import map:
> v.in.dxf
> created areas:
> v.type input=map1 output=map2 type=line,boundary
> v.clean input=map2 output=map3 tool=snap thresh=0.0001
> v.centroids input=map3 output=map4 option=add
> checked with v.digit (strangely v.centroids always categorized in the
> same
> way, but in the outer ring it mixed up two areas, but that was easily
> corrected by manually changing those two categories)
would
v.centroids input=map3 output=map4 option=add cat=<cat_max_val + 1>
help?
